Alternator Regulator
Does anybody know whether in the Yaris Verso 1.3 2001 GS
the alternator has a power supply regulator inside it or is it external.
I have changed the alternator and Battery, but the supply voltage seems a bit high,
and the Battery is over charging.............
please help
Anton
I have changed the alternator and battery, but the supply voltage seems a bit high,
and the battery is over charging.............
please help
Anton
Anton
The alternator is regulated and should put out a voltage of 12.9 to 14.9 volts.
What voltage are you getting at the Battery?
Pete
