Extended Warrantys?
irishjay
anyone know if there are any extended warrantys on the toyota avensis d4d 2003-2008??? am i right in believeing that toyota have extended the headlight warranty to 100k because of problems with the bulbs melting the bulb holders???????//
hello
mine is from 2003 and I was forced to change the left side unit assembly after 3 years in 2006 due to the same problem of melting.
this was done under warranty.
cheers/Igor
