2.0 D-4d T Spirit Tyre Pressure
sprinter400uk
Hi Guys!
I've only had my Auris 2.0 D-4D T Spirit a few weeks and I love it!
Anyway, I wanted to check the tyre pressures today but my Handbook lists all the pressures depending on the Engine Type/Number which is apparently stamped on the side of the engine block but I can't see it without taking off all the plastic covering... surely there must be an easier way?
Cheers!
tells you inside glove box or on drivers 'b' pillar, cant remember which on an Auris lol.
Mart.
On drivers side "b" pillar. Big, white sticker. ;)
Cheers.... Found it on the "B" Pillar - Can't believe I missed it!
Alternatively you may want 37/38 psi on the front to irradiate edge wear with around 33/34psi on the back to prevent wobble.
