Lucida 2.2td 1992 Help Please!
familyman
hi iv bought my self a lucida 2.2td which i love got it for £400 bargain or was it? iv discovered patches of oil or diesel underneath after further investigation i can see it dripping!! help wat could this be?
Could be worn out seals needing replecement. otherwise, trace and see where the leak is coming from as it could also be broken pipes (enjector pipes) where diesel is coming from.
took to garage they said its diesel and its leakin from pump they said it may be that injection pipes !Removed! lose if so will cost £20 labour but if its not that then it will have to be sent to specialist and could cost around £300 to sort out! ant advice pleeease
