Radio Access Rear
john4812
I AM considering connecting a bluetooth hands free device to my yaris 56 plate, in order for it to integrate with the radio and utilize the Speakers i need to access the rear of the radio anybody any ideas.
Cheers
John
Its simple...
Pull off the grey plastic strips up the side of the radio, they come off quite easily when pulled hard but carefully
Now remove the speedo housing, it unclips from the top first, its a bit tricky, but it comes off pretty simply, it slides forwards at the end be careful.
Now remove the 4 screws holding in the radio, and pull it out.
You're all good to go!
There are some desriptions on this site if you look around.
Its simple...
Thanks for advice you are right following your concise instuctions it was simple.
Cheers
John
