Unknown Switch
Green Goddess
Can anyone help? I've had my Roadster for about six months now and I still haven't worked out what one of the switches does!! The only documentation I got with the car tells me that it's the traction control on/off switch, but mine is not tiptronic. I've blown up interior photos on eBay and seen the same switch on other cars. It's just to the left of the steering column, it has two small rubbery swiches (one with a small 'pip' in the centre). I've assumed it's something to do with the Clifford alarm that's been fitted. Any other theories?
Can anyone help? I've had my Roadster for about six months now and I still haven't worked out what one of the switches does!! The only documentation I got with the car tells me that it's the traction control on/off switch, but mine is not tiptronic. I've blown up interior photos on Ebay and seen the same switch on other cars. It's just to the left of the steering column, it has two small rubbery swiches (one with a small 'pip' in the centre). I've assumed it's something to do with the Clifford alarm that's been fitted. Any other theories?
Yes sounds very very much like the override for the Clifford alarm. If your fob stops working you can enter a 4 digit code using the buttons and it disables the alarm so you can drive home.
One does the numbers and one is like an enter (I cant remeber which way round but its in the Alarm book.) Yours will have its own unique code. If your code was 1234 you would press the number key once > enter > the number key twice > Enter etc.
If you dont have the code from the previous owner then will need to go to a Clifford installer and get them to reset it.
