Diesel Rav Missing..idling Unusual
deirdre
I have a 2005 diesel Rav...recently she has started missing slightly going round corners, and idling funny...she has never cut out though, i changed fuel/air filters and added an injector cleaner to tank as well. Any ideas? She is still going well but the missing concerns me...no lights on at all on dashboard. Help! :unsure:
Look at the engine mountings to see if one is allowing the engine to move more than usual.
In any case, try moving any wires or pipes around the engine to see if something affacts the idling as it is obviously a fuel or wiring problem. If you can find nothing then it becomes a bit harder. If the fuel is surging around curves it sounds like low pressure. This can all be checked but you may need some help unless you are mechanically minded?
Regards.
