Advice On Issues
stuartgr
Hi :unsure:
PLEASE REPLY ON YOUR THOUGHTS ON THIS SUBJECT
SHOULD I CONTACT MY TOYOTA DEALER ?
I have a Toyota Auris 1.6 TR, it is now about 15 months old and has done
about 13,000 + miles
1st issue
the Rear wheels are getting dirty with brake dust real quick whilst the front
alloys are still pretty clean.... the brakes on both the front and rear have been
changed on warranty due to a couple of problems before
Should I tell the dealer about this ? does anyone think there may be a problem
with the brakes that is worthy of toyota checking on the warranty ??
2nd issue :o
i now feel that 10,000 miles plus the car isn't handling very well, and has quite a bit
of body roll ( hope this is not a tyre issue ) is anyone else feeling the same way
or does anyone think there could be an issue with the car
I am looking forward to hearing feedback from you... The more reply's the better
regardless of detail
Stuart :unsure:
:( B)
Hi :unsure:
1st issue
2nd issue :o
Stuart :unsure:
:( B)
Hi Stuart
On the first issue, I am 100% certain you will not get anywhere with Toyota or your dealership ,with excessive brake dust.
The fact is each and every car makes brake dust, and although i agree with you, the rear brakes on the Auris make an excessive amount, i am not so sure its an issue.
On your second point , the excessive body roll you describe, could be down to worn suspension , and i would certainly have the suspension checked for wear . So why not give Mr T a call , and get the car booked in A.S.A.P , ....... because If the car does have a handling problem , you realy should not delay ,
All the best with it , and let us know how you get on :thumbsup:
THANKS :D
I spoke to Square Deal Motors ( Toyota Dealer in Falkirk ) who has booked the car in firstly to check
the brakes and they are going to test drive the car also
I'll let you know in 10 days time
Stuart :D B)
Hi :unsure:
1st issue
2nd issue :o
Stuart :unsure:
:( B)
Hi Stuart
