Leak In Lockable Compartment
Laura81uk
Hi guys, I have just noticed i have a leak in my compartment behind the seat. :angry: Anyone else had this problem? It's actually quite bad and there is a lot of water filled in there, the whole of the material at the back is soaking wet too, so i'm thinking it's from the engine somewhere??
Can anyone help please. Any advice appreciated!! :)
Do you mean actually in the compartments, or the flap of material that runs along the back of the compartments like a gully?
I think it's coming from that flap of material yes. The water is just resting in the compartments. The material has gone all mouldy so looks like it's been leaking a while!! Shows how much i use those compartments....
Ditto! Let's hope the material hasn't rotten due to the blocked drains.
The material doesn't look too bad, probably will just need a good clean!
