Turn Out The Light
jmac
hi
i have a y reg 2001 uk roadster. the warning light between the abs and the Battery is on
is this the engine management light if so what should i be doing to sort this prob
is this the end of the world or can i sort this easily enough
Your computer has found a fault in one of the sensors it is monitoring and a steady on light is warning you to take action, you can either go to Mr T's for a diagnostic reading at about £50 to £60 +, check this list CLICKY for someone with a code reader near you or buy a cheap code reader yourself and find out what the code is then go from there :thumbsup:
Les
