3s-fe Cam Timing Settings?
The cam belt on my 94 Carina E 2.0 has jumped a couple of teeth. The Haynes manual is particularly vague on setting up the cam sprocket for the 3S-FE engine. Does anyone have a fool proof method of setting the cam timing? Cheers. Pete. :(
Check your PM box for message & if your happy to receive document via email let me know. Regards, Beagh.
PS: If you prefer PM only & you know PM procedure for sending documents let me know & i will give it a go that way.
Sorry. Should have pointed out your engine is an interference engine & as such it may be likely that you might have some valve damage.
