2.0ltr Turbo Diesel Camry
Hi All! Just joined as a member and wondered if any of you good folk own an import Camry ZV 2ltr Diesel turbo from around the 1991 age group. Owned this majestic old thing for just over a year and have never seen another the same or indeed any other Camry with a diesel engine? Am I alone?
Also in need of an oil change and wondered if anyone can recomend an online supplier for a Coopers z1044/Blue print ADT32110 or Micro T1638 oil filter? I have been informed these are all a correct replacement but please advise?
Owned one for several years, 5spd manual.
The change to low sulphur diesel caused trouble with fuel pump seals here.
There were lots of them on our roads, ex Japan. Most of them are automatic, which made them slow. 5spd was quite respectable. Broken cam belts probably killed the rest, changed mine myself.
I had issues with the rubber bend prior to the turbo inlet coming off or tearing. I think this was largely due to rough gear changes.
Also got sick of changing oil & filter, servicing requirements of turbo diesel are more than I could be bothered with.
Aside from that, I really liked the car, drove it all around the country, top speed more than 180km/hr (slow to accelerate after 160).
Still have a filter in the garage.
Engine is used in other toyotas, there was some information on the net about adjusting the fuel pump. Was going to play with this & boost pressure but never got around to it. Stock it ran 10psi.
