Colour Code?
lewo_rolla
i need the colour codes of this car, the dark side of the bumpers is which i need especially
if you know both of the colors code, you should write them, its better for me :)
thanx
did you look on the stickers on the either the inside of your door? or the chasis code sticker?
on my corolla it is written as '1C3' ....other have something like 'C50' or 'C23' for example.
check for those if not best thing to do is ring up toyota customer services and ask them. i did that to clarify mine and all they require is your car reg. number and they will tell you.
hope that helps :)
our cars hasn't double color, only liftback models are double colored.ours are sedan :(
couse of this it's not enough :o
we need only darker colors code now :)
i see. well in that case. just ring up toyota customer service. i just looked on their website got the number and called. took litrally 5mins and finished.
call them and tell them you would like to clarify your colour code. they will ask for your reg. plate number. and bingo! they will reveal your colour code to you. thank you and goodbye.
