Brake Fluid Change 2005 Corolla
Geriatric
is the extra cost involved for 5.1 worth it ona diesel rolla? or is that the standard grade toyota use?
from my experience a lower grade will be more than adequate for general road use.
Thanks for replies. Is there only the four brake slave cylinders to bleed or is there another nipple elsewhere?
Does the ABS affect the process in any way?
Have only changed fluid on older cars without ABS.
