Electric Windows '95 Carina E Gli Jap Import
Hi there
Second post on here...it's a wee bit bizarre, so maybe someone can point me in the right direction.....
I replaced the offside window regulator unit.....regular part (the part I took out was a Supra regulator, not surprising given I have a Jap import)....but for whatever reason the switch works in the opposite fashion...press up to get the window down and vice versa....but it works fine
I'm assuming I just fitted the mechanism wrong....but now the other three windows are non-functional....when depressing each of the three switches and nothing happens, but my offside regulator I fitted works away just fine (but in reverse, as described)...they were working for a while, but now they have failed.
Anyone any idea if it's something simple like a fuse/relay/switch and/or my inherent stupidity that is responsible, and how can I right the wrong so to speak/
Cheers
Jonny
Sorted folks...sorry for wasting your time, but Dufus here had the Window lock switch engaged.....embarrassing or what...well with that level of competency that's why I am resigned to post for help here.... :rolleyes:
