Tns Sat Nav Issues
rob virgo
I having problems with my 04 t-spirit sat nav for the past few weeks.the unit is switching on and off constantly.it appears to be a faulty /damaged wire but it may be a common fault so some one may be able to point me in the correct direction.
I also have an issue with the heated rear window which may be connect,when i switch it on it creates interference on the radio.
ring any bells
rob v
