HI CAN ANYONE HELP THE FRONT Speakers IN MY 57 BLUE SOUND CRISP AND CLEAR BUT THE REAR ONES SOUND MUFFLED ALTERING THE FAD MAKES NO DIFFERANCE ?
HI CAN ANYONE HELP THE FRONT SPEAKERS IN MY 57 BLUE SOUND CRISP AND CLEAR BUT THE REAR ONES SOUND MUFFLED ALTERING THE FAD MAKES NO DIFFERANCE ?
Do they sound any better when you're in the back? They are directed laterally accross the back seats, so from the front you won't be able to appreciate the sound definition.
Also, don't mistake bass for muffled : the rear speaker are much bigger than the front ones and so have a better bass response. :yes:
Thanks Smoothound but no,they sound exactly the same in the back. Wonder if my head unit is duff ?
I don't know which year a "57" is from, but if You've actually got REAR Speakers instead of an extra pair
of Speakers in the front door, connected to the rear outputs it's not that weird that the rears sound muffled.
The fronts (near the windshield) have a set of tweeters connected, the rears don't, so they
miss a bit of frequency response in the higher (read "crispier") regions of the audible spctrum.
I don't know which year a "57" is from, but if You've actually got REAR speakers instead of an extra pair
of speakers in the front door, connected to the rear outputs it's not that weird that the rears sound muffled.
`Jan van de Wouw Hi Thanks for your reply,57 is the year 2007.My problem really is that if set my FAD control,to just rear Speakers,the volume is really low ie:-vol set to 20 you can only just hear them. Vol set to 20 for front Speakers and its quite loud, i thought that using just front then just back the volume should be roughly the same, hope this makes sense to you
aygo blue 2007
2 Speakers front near windscreen
2 tweeters A pillar
2 speakers in rear doors :thumbsup:
Have you tried turning treble way DOWN and bass way UP and then using the fader?
Does this make any difference in volume between front and back???
Unfortunately I can't test this on my own car as I have an aftermarket radio in mine,
with filtering applied to the Speakers and a subwoofer under the passenger seat.
On top of that I've got my fader playing less than 20% over the rears, as I feel music
should come from upfront. At a concert no one listens with their back to the podium either...
with filtering applied to the speakers and a subwoofer under the passenger seat.
jan van de Wouw thanks for that suggestion its made a lot of differance sounds quite good :D
You tried switching the rears out for decent Speakers?
Coincidentally i have a set of shiny infinitys that came out of the back of my Aygo before i chopped it in...only 4 months old.........
