D4d Heater
choppy101
got a 2003 53 D4D and the heaters are permantely blowing cold regardless of switch positions,engine starts and warms up fine no overheating prob's.
Any help
Choppy101
Any help
Choppy101
check coolant level . it could be low
Had the same problem recently with my 2.2d 55 plate tourer - just out of warranty.
Indeed water level low. Did you get gurgling in the heater pipes on startup for a while?
Try filling it up with water while the engine is running (bet it's short), then I think you'll find it's bubbling in the header tank.
If so, welcome to the blown head gasket club.............................
im a memeber of that club too ,,,, the 2.2 head away club!
