Was out in the buggy last nite and when i reach 3000 revs in 4th gear the ecu light and the trac control light comes on every time i do it..? any ideas /
And another teaser, if my speedo is disconnected from the car does that mean the the speed cut does not take effect..? if u can help i would be very gratefull :thumbsup:
Is it disconnected now? if so that is your problem, the ecu will sense a speed sensor failure or something similar
Check for error codes on the ecu that will tell you what error has been reported,
not a good idea to disconnect speedo...just delimit it.
HTH,
Mo
HTH,
Mo
Didnt do it on purpose , just kind a happened....? :(
