Has My Cam Belt Gone
box
hi sorrey its a 1998 2000 68000miles misses stoped as as usual bat was a bit knackerd so i got a new 1 and plugs but wont start
there is a spark at plug
Better getting a mod to shift this to the Rav forum mate. Our resident Mk1 Rav expert is Bothwell Buyer who
may be able to help. :thumbsup:
Happy to oblige...............Well it is nearly Christmas ;) :lol:
hi how cani tell if my cam belt has gone any idears
cheers
Hi there..remove the oil filler cap get the missus to spin the engine and look in the oilfiller and if the camshaft is rotating the belt is still intact, if nothing moving then the belts gone. :(
keep your fingers crossed :unsure:
cheers
Good advice........................but how can he do that if he has his fingers crossed or no missus?? ;) :lol:
He could use a couple of mirrors and a bendy straw... I knew years of watching Blue Peter would pay off one day :)
if you've followed this so far, its too late!!
The 3SFE engine wots fitted in your car is an 'interference engine' - ie if the the cambelt breaks then the pistons will bounce off the valves and you will have a selection of bent valves.
You can try removing the oil cap as said, and carefully and slowly turning the engine pulley by hand with ignition off (unless you are handless)....if the camshaft turns then the belt must still be hanging about. The belt is due a change at 60,000.
If you have followe the advice earlier and the engine is now a lump of scrap metal, you can take it from me that you have no chance of any reimbursement from the muderators!!
Any other symptoms - like run out of petrol.....oil.....black ice so the wheels don't grip....
it kinda sounds as if you changed the Battery (blinkin muds got me for using sland and I have to spend 4 hours translating this???!)
then you changed the plugs
perhaps the immobiliser has activated !!!
ah mean, ye ken.....onywan frae bo'ness using a compressor wi-oot telling us whit air pressure its running at - weel can ye trust her???
Compressors are fur garages and not for Christmas!
For goodness sake don't try and turn it with the ignition until you have checked by turning the crank by hand and then gently to see if the cam is turning. If it is'nt then get yer spanner set ordered for christmas cos this will be expensive.
Happy new year. :rolleyes:
