any way to make it brighter??
Not AFAIK...
Illumination is done with SMD-LEDs soldered onto the speedo/ECU PCB, so if you want
to make 'em brighter or another color you have to take apart the entire speedo...
I DID come across some topic elsewhere in which someone had
made his own speedo-face and used Plasma-illumination...
Unfortunately it is all in German:
http://www.iphpbb.com/board/ftopic-4164186...-120.html#32282
