Egr D-4d Engine
andyhep
I cant believe no one on here knows where the Egr valve is located on a Avensis d4d !!!!!!
Come on somebody must,never mind tit tat about how much it might do to the gallon answer proper questions please.Please
To andyhep,
If you have 1CD-FTV engine, of the top of my head i think you have 2 EGR solenoids precat. one under Maf sensor, next at front of block below to left side of block. And you may have 2 more after cat.
Regards, Beagh.
Hi there its a 2004 Avensis D-4D 2.0l, im having trouble with code P1251 coming up now and again and guessing it could be the egr valve all i want is to get at it and take it from there,cheers.
To andyhep,
Sorry for late reply, just checked posting. EGRs are as stated, but for some reason i have mentioned Lambdas. Discount Lambdas, must of had my a--- in my elbow when answering. Sorry to complicate matters, your car showing OBD11 comliant & thus fault code P1251 showing as air mixture circuit malfunction? If EOBD compliant all EGR codes are from PO400 to PO409, sorry for confusion, but as far as i am aware your car is OBD11 compliant.
Toyota mechanics are on this site, they should be able to clear matter up, sorry i cannot help any more. If you try another posting directly aimed at TOYOTA MECHANICs you might have a bit more luck.
Regards, Beagh.
Hi there im begining to think P1251 is aimed somewhere at the Turbo side of things not sure where abouts tho? Ive given it a Italian tune up and knocked the light off and all is ok so far i think driven very steady by a female with the turbo hardly needed 99% of time really soot's things up so will see how it goes.
