Rain-x
dazwan
After seeing it reccomended on here I bought a huge bottle of the stuff to try :D
Well, after doing 200 Motorway miles in the rain tonight (Thursday) I'm impressed. Most of the time I didn't need my wipers, even when passing trucks.
Anyhow, how often does this stuff need to be re-applied?
I used it once. last for about 3 to 7 days depending on the amount of rain.
But I quit using it and never will again.
After it wares off a little it's near impossable to see through the window. So keep it around, it took a couple months for it to wear off my car I used it on.
But that's my opinion.
I used to use it regularly. I never had any problems with visibility, and it seemed to last about a month, but then again I only did 1500miles per month. I reapplied it whenever I washed the car. If you really don't use the wipers much then it should last OK.
I got some for my mirrors & rear window as it doesn't have a wiper & never really got on with it, perhaps I was appling it wrong? :huh:
Lasts me 2 or 3 mths but you have to do it exactly as per instructions or it don't work, greeaatt stuff i reckon
ps. /I only use my Toy every other 4 days.
So I guess a month isn't bad going really between applications, I just wasn't sure as I reckon I need a top up and thought it may be too soon.
Once I finish with it, I'm sure a good cleaning compound will get it off the glass (won't it?).
:thumbsup:
Finish with it? You just continue reapplying... :D
Anyway - I never had any problems with visibility. If I didn't reapply it then the rain didn't move off the screen so quickly, is all
