Help!
t-sport786
Help please my ECU light TRC OFF light and VSC light has just randomly come on.
Does anyone possibly know why? or has anyone experienced this before?
Thanks.
Thanks.
My ones came on the last day. Came on just after I pulled up at the airport to collect someone. I connected my computer to her when i got home. Running rich bank one. I have a spare airflow meter, swapped it over. Lights are staying off now. Maybe its something to do with the cold weather. The car ran fine while the lights were on all the same.
You wont know what it is until you get someone to get the code for you.
Thanks.
Your lights that came on, were they the same three that have come on in mine?
I'v spoken to my mecanic and hes gona check it all out hopefully tomoro. The car drives fine and everything it just dont make sense.
Yea all three come on if something is wrong. vsc, traction and the mil light
Thanks.
People have reported this after tyre changes and other non obvious reasons, you could try an ECU reset and see if they go away. Hogie knows more about this than me, but i believe the reset puts the lights out and leaves the fault code in the ECU for futher diagnosis.
Thanks.
Kool thanks alot for your advice guys im taking it for a diagnostic first thing in the morning and hopefully that will tell me what the problem is, hope its just something small and minor.
Thanks.
No I dont think it does. It wipes the code completely. Get it scanned and turned off an see does it come back on again. That's the best thing you can do
The diagnostic showed up the air pump.... the lights have been cleared and havent appeared as of yet loll but im taking the car in to get the air pump looked at on monday. Thanks for the help yea!!
