98 Corolla Immobiliser?
chris20051
Im trying to find out if my 1998 Toyota Corolla has an engine immobiliser? I open my car door with a key and turn the key in the engine, is there an immobiliser in the key?
:huh: If the car starts then, no there isn't.
The car shouldn't start unless you use the fob to unlock the door rather than just the key. :unsure: At least, that's what happens with my dads coupe.
there is one, and the key actually has a transponder in the actual plastic bit of the key and there is a sensor thing near the barrel, so once the key is in the barrel the immobiliser deactivates! making it impossible to hotwire the car!! :)
Touche bigshark, touche.
:nerd:
