Weak Rear Screen Demister
dkan
Hi All,
I have a 53reg Avensis T2, recently found the rear screen demister to be very weak. It use to be very quick in demisting in the past, but it's taking ages in the current weather. Any ideas what I should check ? I think it's working just not very efficient. I've check fuses, and they are ok.
Any ideas would be great.
Cheers,
Give the inside of the window a good clean - sometimes this can help with demisting.
Also if you take a look at the fine 'heater' wires running across the rear screen you may find some are broken.
Mart.
