Indicators/hazard Lights
Buzz1974
Hi have a 03 Avensis(new type) and want to replace the fuse for the indicators/hazard lights but cant find it!
Hope someone can help,
cheers,
Buzz
To Buzz1974,
Your main fusebox is behind your glovebox, loosen damper & remove glovebox. You should have Blue/White sticker showing fuse position & ratings. Also you do have another fuse box on drivers side just above your OBD connection, this is a little harder to access, but i have a feeling fuse your after is behind glove box.
Regards, Beagh.
To Buzz1974,
You don't say model. But looks like you may have relay or fuse for Hazard/Indicators in main engine bay fusebox near Battery. Two other internal fuse boxes have relays fitted ? Using "Autodata" disc but manufacturer do not release complete info for cars. Hope this helps.
Regards, Beagh.
