Slight Noise When Accelarating
lift addict
I seem to be experiencing a very slight drilling noise only faintly and only accelarating very lightly in first and second gear i.e (1000 - 1500 rpm)
Does anyone have any ideas what it could be ?
If you are hearing a high pitched noise, then it's probably something to do with the gears slipping slightly. A mate had the problem with an old mini and the gears were slightly worn when he took it apart.
Is your rolla old or thrashed around alot?
Thought you'd sold the CTS?? :huh:
