Corolla T Sport Head Light Problem
b1gpkr001
hi all
got a problem with my head lights as i drive with them on they go dim every so often usualy every 5-10mins for a second or so then brighten up again does any one else notice this or had a similar problem?
any one got any ideas?
thanks
hi all
thanks
Does this happen when running a lot of electrical stuff at once e.g., Heated rear window/Air Con/Stereo etc? On mine if all this is running when the Air Con compressor kicks in you get a slight drop in revs when at idle and the lights dim momentarily as the alternator is received a lot of draw to power all the electrics.
hi all
thanks
i would guess yours is a pre facelift as they did have this problem it is covered in past posts somewhere .its to do with the ecu or something but it isn,t actually a problem i had it on my facelift tsport and never let me down :thumbsup:
