Error Code P0755 - Any Ideas
drjonesguru
Hi all!
Just wondered if anyone can give me a clue on the problem with my aunts year 2000 1600cc auto corolla. She has had the AA out on 5 occasions because of an engine warning light on the dash, and they have advised it's throwing back a fault code of P0755 "Shift Solenoid". Has anyone got a clue as to how much this would cost to fix as the local garage are saying it needs a gearbox strip down to fuind the fault!! Also she is unsure whether to drive it or not.
Any help/advice would be great!!!
Thank you
Doc
Does the car stall/gears cant be selected? Do the AA come out because of the warning light? Can you elaborate further?
If its the gearbox solenoid and its in the gearbox then a strip down would be required. As for the cost then Mr T would be able to price the part, after that you would be best seeing if a pattern part is available from a motor factor. Get an estimate from a Gearbox specialist for a strip down and part change and you have your cost.
If its safe to drive really depends on the 1st questions.
That's the strange thing, the car drives absolutely fine! The manual says dont drive it, but obviously Im a bit worried!
To drjonesguru, Shift solenoid B malfunction. Forget local garage stripdown, that's one for Toyota. I would cough up for an hr's diagnostics check with the correct hardware/software.
Regards, Beagh.
