Idle Problem Got Worse!
kangzy
guys problem has got worse...
nw da car starts struggles for revs n cuts out!
im thinking it mite me da idle control valve dat needs cleaning or da maf sensor? how wld i clean da idle contol valve?
where can i get carb cleaner from?
wat cld b da problem?
any ideas?
cheers shaun x
Is there something wrong with your keyboard?
English, it's your language, use it properly please!
kangzy have you still got warranty. I would take the car back to toyota, try and put it back to stock as much as possible. put your original wheels on etc as for the exhaust let it go in how it is. As its a compressor say you bought it from the dealer like that!
As long as you make it look as stock as possible have them check it under warranty. The problems on your car have all popped up together. Would be wise to get a check up to clear any fault now than to have something get worse later.
If you describe the Problem to the your dealer as you have done here i'm sure you won't have any issue's.
jbnfdgbkndfgnksnbndn bndf rgndfsvoin rnvonvfdsoi nsvn ivoins.
hi, theres no point in guessing get it on a scanner! seems funny since you now the cats gone its all started goin wrong,scanner is the way forwards me thinks.
thanks for your constructive post!
i assumed that all members on here were bright enough to understand short hand..obviously in your case guess, you are one member i must of taken for granted!
anyway moving on a more productive note..
my car is up and running perfectly..the problem seemed to be over fueling which was soon rectified by keeping my revs high and burning off all the excess fuel!
next sat i am getting my new 200 cell sports cat fitted.. which coupled with the existing system should see me gain a few extra ponnies..
thanks for all ur help guys
Next sat i am getting my new 200 cell sports cat fitted.. which coupled with the existing system should see me gain a few extra ponnies..
How much is the new cat going to cost all in? Are they made to take the lamba sensor?
the sports cat is from the ppl that fitted my catback system.. its gonna cost me £265 fitted.. honestly i couldnt recommend them enough!
its a unversal cat but given that my current cat is a 400 cell one it should b a hapoy medium and not to irritate the lamda.. hopefully!!
Thats better. :D
I am guessing its got a hole for the lambda sensor then, it could release a few horses as well.
Good Luck, feedback if it makes any difference to the way she drives :thumbsup:
