How Do Yo Remove The Riser Blocks (gt4)
gt4WRC
Planning on painting the gt4 riser blocks, taken spoiler off, then removed inner section of the riser block, but hit a dead end as the two bolts holding it on the spoiler are fix only, not capable of being unscrewed!! wierd head on them!!!
This is the annoying wee things here booster!! one way only it seems!!! But you have them out already i hear you say!!! Thats because i resorted to ramming a 11mm socket down on them and with a bit of sheer power they turned, as long as you kept the pressure on!!
Thanks anyway :)
i know the riser blocks need a special fitting kit , so obviously its a tool you need to do up those bolts , i have read about lads using an ordinary bolt instead of buying the fitting kit. maybe thats your way forward on reinstalling them ?
