Help Regarding Wheel Spacers!
farhanali89
Right guys need your help yet again! My wheels fitment is 4x100 ET42 (Offset)
I wanted to use spacers on the back wheels to get them inline with the arches. I dont want them poking out of the arches but i want them more inline, how the front are. Which spacers will help me achieve this, i have a pair at home which are 9mm thick, i think they maybe to thick to use on the standard studs.
Any advice on spacers which size spacers can be used without the need for extended studs? any info would be appreciated.
Try Europerformance for spacers, but I'd reccomend that you didn't get them because they wear you bearings down faster, which can prove to be expensive if you get really big ones which make it worse.
It's your choice, just trying to help a fellow rolla owner save his cash! :D
thanks fella i was going to use small spacers just to pull the wheels out a tad bit more? Anyone else got any suggestions or who could recommend a size ?
A small amount shouldn't hurt too much then!
As I said before, go to Europerformance.co.uk and they sell some 20mm spacers (10mm each side) which should do the job! :D
i got 1inch spacers on mine lol :lol:
LOL damn ! one inch. will probably put on the ones i have at home see if they fit and then go from there, just worried about having to get extended studs thats all. Trying to save on labour costs!!!
