Engine Oil Change Gen 7 Vvti
vvti_fan
Ok, possibly a silly question, but i'm going to make sure just in case.
I've been using Semi-synthetic engine oil.
Should there be any problems draining and putting fully synthetic in?
In a word, no. Either 5W30 or 5W40 will be fine :)
Ok Thanks mate.
  • 4 weeks later...
Whats the difference between semi and full synthetic oil?
I use semi
Synthetic oil is oil consisting of chemical compounds which were not originally present in crude oil (petroleum), but were artificially made (synthesized) from other compounds.
Semi-synthetic I guess contains both nautural & artifically made compounds.
