Any One Know Where I Can Get A Induction Pipe
b1gpkr001
hi all
im looking for a induction pipe to fit an apexi induction filter ive got any one know where i can get a induction pipe?
Its for a 2002 t sport
Is it the pipe that leads into the throttle body or a cold air feed pipe? If its the later then eBay has plenty, if its the former then no idea!
Is it the adapter you need?
Can't say i've ever seen them advertised.
Bought my kit from Nengun which came with everything needed.
You could always contact them as i'm sure they would be able to supply the adaptor
Nengun
:thumbsup:
Im after the part that houses the air flow sensor that then goes to he throttle body i think.
HTH! :thumbsup:
And to tease you slightly... here's one i made earlier! :lol:
you made the adaptor pipe for the flow meter your self?
want to give me some idea how you did it as im an air craft engineer and sure i could make one up just need to know what needs to be incorporated
thanks
out of interest did the filter actually make any difference to you performance/fuel consumption or did it just make it sound a bit nicer?
thanks
When i said "here's one i made earlier" i was just meaning the install of the kit! :lol:
The adapter came with mine, i ain't that good at fabricating things!
Fuel consumption minimal gains.
Performance wise it certainly seems to pull quicker under hard acceleration and Lift feels better! :D
As for if it actually added any ponies.. if our 3rd attempt at a Rolling Road day actually happens i'll find out! :lol:
lol well i might give it a try at making one see how it turns out!
sounds good to me let us know what the the difference is once you have been on the dyno. be intrested to find out how much difference it makes.
thanks
