Whays Wrong With My Avensis
oreillyjason
hi my toyota avensis wouldent start this morning so i tryed to jump start it. when i did i let the clutch up and heard like a brakeing sound then when i tryed to start it again there was a load of smoke comeing out the exhaust when it tryed to turn over thanks
Sounds rather serious, best get a mechanic to take a butchers at it.
tyre squeal--probable tried to start it in 1st gear--(to low 2nd much better ) if you attempt to start with low starter motor speed (week battery) you build up unburnt gas,and oil, in cylinder,hence smoke,try spaying with WD40 and charging Battery
tyre squeal--probable tried to start it in 1st gear--(to low 2nd much better ) if you attempt to start with low starter motor speed (week battery) you build up unburnt gas,and oil, in cylinder,hence smoke,try spaying with WD40 and charging battery
Did he mean a braking sound or a breaking sound? I took it to be the latter.
I think more info is required. Was it a breaking sound or a brakeing sound?. Was it a jump start or a push start?. :huh:
