Removing O.e Stereo On T-sport
waldo87
Hi mate easiest way to go about it is to firstly
Remove ashtray
pull up gently on gear gaitor plastic
Pull the centre dash panel from underneath towards you and slowly nudge it out.
You will then see 4 nuts holding the headunit in place remove these with a socket spanner and ease the whole stereo surround and vents around it.
Next the original headunit is held into the surroun with small plastic edges just remove the stock headunit from the surround and there you have it.
Let me look for the stereo removal post with photos will make it much easier.
