Gen 7 Ts Tyre Setting
GreyRacer
I have not got my owners manual here and have not got my full membership through to post in the question in Gen 7 section.
What is the high speed PSI setting for driver only with standard 205-45/17?
I know the standard driving pressure is 30psi, and to be fair you'll find it runs wide all too easily with pressures much higher than that if you like to throw it into the bends.
Not sure if yours is the same, but mine has the pressures on the slam panel just inside the passenger door.
