Rear Window Wiper Madness
Milzeh
I ordered a rear window wiper from a well known online company. My g/f's Yaris T-Sport is 2001 & no way would this rear wiper fit. I'm guessing her T-Sport is not french fitment. Where can I buy the correct wiper from & if anyone wants a french fitment one I'll post you it.
Thanks.
Thanks.
You could try your local Toyota dealer and give them the chassis number...................or send Kingo (Parts King) a PM :thumbsup:
Thanks.
Yeah I'll go to the main dealer it's only up the road. sod it be decent part.
You only need change the blade not the arm on the rear wiper. About £3 from Toyota. Bit of a fiddle to fit and you have to re-use the metal inserts fron the one you take out but it only takes minutes to do.
Not correct I'm afraid. All Jap built rear wipers are a combined arm/blade. A French built blade will not fit a Jap built car. If your Jap built car has a damaged blade, then it forms part of the whole arm and you will need to replace it at about £55 ish complete. You could buy just a rubber and insert it into the metal inserts if it was just the rubber that was damaged, but any damage to the arm means a new arm
Kingo :thumbsup:
