Difference Between 140 And 190 Engines? Gen 7?
craigycakes
:) hi guys new 2 the site and i have always wonderd wat is the difference betwwen the 2 engines? and can u make a 140 in to a 190?
sorry if its a silly question just sumfing i would like to no.
cheers
Although the 190 (VVTLi) is based on the 140 (VVTi) they are in fact fairly different engines and therefore you can't just make a 140 into a 190 as such. They have different blocks and different heads, with the 190 having an extra function built into the inlet cams to enable them to open further after a certain point in the engine revolutions.
There are however supercharger kits that take the 140 up to 190 and beyond. In fact Toyota did a limited run of supercharged versions.
More info here
http://www.celicas.co.uk/Celicas-Gen-7.html
and here
http://www.celicas.co.uk/Technology-Vvtli.html
Theres also plenty more on the internet despite these two links.
Hope that has helped explain it somewhat! :thumbsup:
My lovely Celica; I wonder where she is now? :(
As sjrainsford says, conversion of a 140 into a 190 isn't really a practical proposition; unless you're Yamaha that is.
The better options would be to find power some other way, or else trade a 140 in for a 190.
Or if your budget is unlimited go the Fensport GT4 route; that's got to be the ultimate Gen 7.
hi guys ye that helped me out cheers.
1 more question is i seen a clip on you tube of a gen 7 reving past 7000 rpm is this correct. as mine limits out when it hits the red?
cheers craig
cheers craig
The 190 engine has a higher rev limit, 9,000 rpm. Although I rarely get that high, but it is fun to get to near 70mph in second gear! :D
