hi can anybody help..ive got j reg surf 2.4 and someone has bodged up the wiring for the fog light im wanting to rewire it but there is a fog light switch on the centre console....is that for the front fog light switch as theres none fitted to that or is it for the rear fog light as im unable to trace the wires from that switch to the rear fog light,ive traced it to a relay then the wires go right to the back of the dash...any advice would be great..cheers
i own a 3.0 surf.ssrx. and the button on centre console next to the rear window button is for the FRONT fogs. and the rear fog switch on mine is on the right of steering wheel near idle and suspension button. hope this helps..
I have a 2.4 SSRX and the switch for the rear fog light is on the centre console next to the tailgate window switch.The foglight indicator is on the dash right hand side of the steering wheel.Good luck!
cheers ricster but im unable to trace the wires from the relay which is cable tied to the steering column then wires go to top of the dash but cheers mate
