Key Programming ?
mennace
Hi Guys and a happy new year
Can anyone shed some light on my problem Bought a new 2 button key for my rav from dealership Thanks to the forum i have managed to programme the new key so that it locks and un locks just fine but will not start the car ?? have i missed something ?
appreciate any thoughts before i go trotting off to the main dealer
:o kindest regards
mennace
I don't know the vintage of your RAV, but very often as well as the remote lock/unlock, for engine immobilisation the key contains a separate transponder (a small electronic pill like device), which would need programming into the vehicle as well.
Certainly it was the case in the past with other vehicle system I've seen/worked with. I've never looked closely enough at the RAV's system, so I could be wrong.
Many thanks will look into the possibilities of this
have a great new year regards
dave
You might want to try this. I found it through google, so I don't know if it works, but it is worth a try.
For 1998+ Toyota, Lexus
Add Duplicate Key
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert existing master key into ignition.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and
remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. After 80 seconds new key is registered and security light goes off.
8. Remove new key and depress and release brake pedal 1 time.
For 2002+ Toyota, Lexus
Add Duplicate Key
Requires one working Toyota/Lexus Master Key.
1. Make sure all doors and windows are closed.
2. Insert Master key into the ignition cylinder.
3. Cycle the ignition cylinder from On to OFF five times.
4. Open and close the driver side door 6 times.
5. Remove the Master Key and insert the new duplicates key.
6. TURN THE IGNITION CYLINDER ON.
7. The new key will be registered after 60 seconds. The THEFT light on the dashboard will go out, indicating that programming has been completed.
source: http://en.allexperts.com/q/Toyota-800/Prog...onder-Key-1.htm
It would be nice if you could confirm that it works or not :)
Hi all. Newbie(sort of) here, I can confirm that the reprogramming works! bought an empty key case off eBay for £5.00, Today, I had a £2.00 key copy made, and followed the instructions. Result, a new key that works. (My old one had the plastic broken)..
So thanks for the heads up St Thicket!! :thumbsup::yahoo:
