1995 2.2td Auto Lucida Estima Starting Problems
my lucida is having problems starting.it gives the impresion that the Battery is low it is a new Battery,also have changed starter,cleaned earth leads,now run out of things to try.can any one help.
  • 2 months later...
my lucida is having problems starting.it gives the impresion that the battery is low it is a new battery,also have changed starter,cleaned earth leads,now run out of things to try.can any one help.
Had the same problem 3 years ago......turned out to be the switch for the curtain grounding off; suggest you get it to toyota for a diagnostic around £80
One can't make wild assumptions that the problem you had before is the same as this person is having. It could well be but there are so many things that could have the same symptoms.
Could you give us more info e.g. Does the engine turn over or are you just getting a clicking sound. When you try starting it does the engine seem to lock up and/or is there any smoke. etc etc etc. The more information you give the higher the probability of an accurate diagnosis.
