Rear Wiper Not Working Properly
dave dee
Hi all!
My wife has an '04 plate Yaris and the rear wiper has decided not to work properly.It'll move up OK but will stick when it gets to the vertical and needs a little nudge to get it to go back down (feeling of De-Ja-Vu here!) it will then move back up and then stick again.When it gets to the vertical you can hear the motor but it just won't move again.I've tried it with the arm pulled away from the window (as if for cleaning) and it is still the same, so I'm guessing there may be a problem with the motor? There seems to be a slight bit of play in the arm but this seems to be on the inner side of the tailgate rather than maybe a loose nut at the "elbow" on the outside.
Any suggestions would be great.I've already asked this question on the Yaris forum but with no success.
Many thanks and all the best for 2009.
David
Hi cmia.
I'm not too sure what "2) motor is furbared" means. In fact I haven't a clue!
Do you think it would help stripping down the motor (if that's possible) and giving it a good clean and a dash of lubricant?
Many thanks.
David
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
