£75 Induction Shipped Over From America
crinks85
does any one think is worth the risk of it not fitting properly ? i am temted. what do people think.
i wouldnt take the risk there mate, that induction kit has no place for the MAF sensor. You need somewhere for that sensor to fit in properly if not your trc,vsc engine lights will come on. I think you will also go into limp mode. I would stick to a induction kit from the uk made specifically for the UK T-sport
it has got a place for the maf, its welded to the pipe. Stil wud stick to kandn, apexi, powertec, blitz or pipercross tho
oops! my bad had a closer look. Its there, not bad for £75 but as akatheking says would stick to the better known brand around here ;)
i was thinking if it doesnt fit quite right where it goes down the original air flow route, i know it will fit to the engine so just cut it shorter till it fit, saves least £80
decided not to buy cant be bothered with it not fitting i will keep looking
