hi, i have a 1993 toyota previa (automatic), the engine management light keeps coming on when i hit a certain speed, its like its missing gears! does anyone know what this could be? also, what is the OVERDRIVE button for?
You need to check the code to see what problem you have - go to :-
http://www.batauto.com/
The overdrive button is for an "extra gear" - when your on the motorway at legalish speeds,press the button to select O/D,the revs drop and saves on fuel.
Much appreciated, THANX!
