St202 Ht/ignition Leads
WannaBeRacing
Can anyone help me out with a set of HT Leads for a Celica ST202 GT 2.0 on a (M) 95 plate?
How about making up a set for yourself :unsure:
The job is so easy and you can save yourself quite a bit of money. Get down to your trusted parts shop and see what they can do to help you with the supply of the parts you need, just make sure you measure the existing leads properly and then add a little, say 10%, extra for wastage. :)
try eBay mate , a few being broken on there . stick with the stock leads nothing else is as good. plus the ends clip onto the dizzy cap to seal them from dampness , others wont. ;)
