Back Brakes Grinding
RossGCX
My Auris has had this problem since I got it I have been back the the dealers several times and the say its a "common" problem they have got bad its worse at lower speeds but it shouldnt be the front ones are fine.Iam going to try a new set of pads to see if that helps.Dose anybody have any other suggestions?
Hi ross
Your dealer is right in that its a common problem with the Auris, much has been written and said about it on the forum
below is a thread i started a while ago, look it up and have a read.
Brake Squeal Issues ( Do You Have An Oppinion )
Have you had the mods carried out , and if so has it worked ?.
Hi ross
Thanks Iam going to replace all of the pads soon because ive done 17500 miles now on the originals.
Hi ross
There is a technical bulletin for 'groaning' rear brakes on the Auris. The fix is to fit modified rear pad carriers.
Mart.
