Rear Wiper
Nightstalker
Lo All.... :lol:
Looks like it's time to replace the rear window wiper... <_<
Anyone know how to do it... looks like it could be a bit of a pain in the a :ffs: :censor: :ffs:
Regards
Rob
B)
Aye thats it.
What he doesn't seem to know is that if he buys the front one it is only $2.74 for 24" and you just cut it off to length!!!
Volume related price I guess.
Well Thank you Chaps.... :toast:
Looks like its gonna be Fiddely Fun.... cant wait :drool::wacko::blink:
Think there might be a bit of this going on too ... :censor: :ffs: :bash::bangin::boxing: :censor:
regards
Rob
B)
NO NO NO NO It's so easy to do...........
Took me all of 10 minutes to do..took longer to drive to Toyota to get the part then back again.....
Just removed the old blade taking care not to bend to metal retainer...then slide our rubber blade and slide in new and replace....easy....
Just do it inside as trying this with freezing cold hands will end up with soar fingers and probably a plaster or two.... :crybaby: :crybaby:
You're right Chatman, piece of cake getting the wiper off...
However where do we get the replacement blades from? Do they have to come from MR T? or are the ones from Halfrauds ok?
I thought I could use my old front ones which I've just replaced but found out that they dont fit... I also dont like the Bosch blades I've got on the front, luckily I kept the original front blades and will be looking at getting some blades for them once I know where to get them from...
A chap at work recommended wiperblades.co.uk anyone used them before?
Regards
Rob
Rob
If you are talking about just the rubbers I get them from the USA so not much help there. However, I have also fitted Bosch rubbers quite successfully but the recess for the stainless steel spine doesn't quite line up but they still work OK.
I think your best solution is Kingo. That fitting for the entire assembly is special and I think you will struggle getting that in any case but Kingo does a range of "Toyota Optifit" blades. These are really good quality with a rust free steel frame and the links have stainless pins rather than plastic so they don't wear then clunk when they change direction.
I think it would be the best VFM.
PS - our US friends will fall about when they see I fit "rubbers" to my wipers!!!
Rob
Good to hear you're playing it safe! You can't be to careful these days!! :D
Rob
Yep and we wear our PANTS under our Trousers :lol::lol::lol:
Ahh i get it now!! "rubbers" Well i have a "rubber" on the end of my pencil which as there is no lead in it these days is rather pointless.. :unsure: A bit like this reply.. :rolleyes::rolleyes:
:toot: Call for KINGO :toot: Call for KINGO :toot: COME IN KINGO..... :rolleyes:
Whats the damage for a full set of RUBBERS nowa-days then? ;)
Cant remember the size of the "wiper" should be around the 23inch ;) mark.... :o
Anywho... all banter by side... could you advise on what the costs would be for the blades...
Ta.
Regards
Rob
B)
Ta.
Regards
Rob
B)
wee Parts-King sorted me with a full set of front wipers for number 1. Great - no rust and 67 seconds to fit. They even get delivered the day before you order them....
Ta.
Regards
Rob
B)
It was yours bothy that first drew my attention to how good kingos wipers are. Since then I've seen some for a 4.3 which are the same quality that shcm has on stand by.
The fronts are 24 and 17 inch.
A pair of genuine "Optifit" Wiper Blades is going to cost about £16 delivered, they are excellent quality, even comes with the drivers side spoiler as per the original. Optifit is a genuine Toyota part, but the range is focused on cars over four years old, to be more competitive on price. The range is getting larger all the time and covers a lot of the faster moving range
A pair of rubbers, Oooh err missus, will cost more like £18 weird I know, but yer rubbers are dearer than blades :eek:
Kingo :thumbsup:
A pair of genuine "Optifit" wiper blades is going to cost about £16 delivered, they are excellent quality, even comes with the drivers side spoiler as per the original. Optifit is a genuine Toyota part, but the range is focused on cars over four years old, to be more competitive on price. The range is getting larger all the time and covers a lot of the faster moving range
You've confused me Kingo... (easily done!) :rolleyes:
Are the "Optifit" blades the same as the original fit or are they a traditional style of blade? :wacko:
Also, does the price of rubbers include p+p?
You must make a lot of mistakes! I have a pencil with a rubber eraser on both ends for the same reason.
On one of our trips to Florida when the kids were only very small, my wife caused quite a stirr when she told some of the local ladies that one daughter was collecting rubbers. She meant erasers of all shapes and sizes from Disney and Universal.
Its a wonder we didn't get locked up!!!
Toyota make a full range of "Genuine" replacement parts, the exact same part as fitted on the car from new. They also make a range of parts called "Optifit" which are cheaper, and aimed at the older car. These "Optifit" parts still carry the manufacturers warranty (Batteries 3 years for instance) but because they are a small specific range, they can be produced cheaper. They may look slightly different, but are excellent quality. They are certainly not your traditional off the shelf blade from a factor. The above prices include p&p
Kingo :thumbsup:
Hey Kingo...
Any chance you could post up a pic of the optifit blades/wipers? This way we would be able to see what type of wipers they are and if they are the same (at least look the same) as our standard ones.
Regards
Rob
B)
They don't look the same Rob. They don't have the plastic airfoil they are a metal framed standard wiper with an additional shield.
They are very well made though.
Sorry chaps but I dont have my camera with me at the moment, here is a next to useless image from a camera phone!
The drivers side blade has a plastic spoiler
Kingo :thumbsup:
If its the optimixthingymajigdooda that you supplied for number 1 RAV, then the blades are
a. still intact
b. still work very well
- even better once a young helpful chap put the blades aerofoilwhatsits the right way up !!! :lol: :lol: :lol: Up til then I was getting the car lifting off!
Hi Anchorman,
have you tried to by "Sellotape" in the US? That leads to trouble too! ;)
a. still intact
Aye thats them, OPTIFIT. Thats what young chaps is for Bothy, blade correction and video player setting :eek:
I often wonder who owns the name "Optifit" I see a brand of those healthy pro-biotic drinks with the same name in one of the local supermarkets, a quick Google of the name shows it is a very popular name!
Kingo :thumbsup:
Hi Anchorman,
Rubbers + Sellotape = chain gang!
"Taking my shirt off here boss"
:rolleyes:
