St185 Leaking Gearbox Oil
OZZY_C
hey guys,
I had to remove the gearbox in order to fit my new clutch for the st185 whilst doing this I must of knocked the joint between the gearbox and the driveshaft and now i am leaking gearbox oil. the car drives fine but i get a slight knocking noise from were the leak is. I have not been driving the car as I do not want to make any more damage to the car. does anyone know what that joint is called its round and it takes 6 bolts. also is this part cheap and easy to replaceor is this part part of the whole gearbox?
any info would be much appreciated. thanks
